Battery Lithium Battery and Long Term Storage
PoodMood
Hi,
I am planning to purchase a 550 in then next year or two. I am planning to store it locally, not in my garage. That means it won't be plugged in for long stretches. With a lead acid battery, I would plan on removing it and bringing it home to place on a battery tender. Do you need to do this with the lithium ion battery upgrade? Can it sit for 6 months and not lose its charge enough to cause damage?
Thanks!
As cary said make sure all loads are off. I added a GPS tracker and its hidden well enough that its a pita to unplug . I've found that after about 4 weeks the battery in down about half. Lucky for me I have a garage I keep it in. But for some reason the ac/ battery charger doesn't kick in once it goes through a charging cycle.so I have to remember to unplug and replug every so often
