12v/12v chargers (CTEK!) and your TV’s alternator
SethB
A few years back I installed a CTEK 12v/12v 20a charger, same as CI supplies as an option.
This morning I came across this test relative to larger chargers and how their loads may impact the life of an alternator.
Conclusion: not a concern when driving (higher alternator rpm). Could be a concern when idling to charge.
(note expected max draw of the CTEK charger is 13.8v x 20a = 276w)
P.S. to non-electric-geeks; this is not cause to panic! CI engineering is solid, this 276w draw is modest, CI has included a safety margin. It does seem prudent to avoid lengthy idling with a depleted trailer battery, TV lights on, AC on max fan, seat heaters, and every other accessory turned on!
On the other hand, if you have a third battery system with its own high draw DC/DC charger this could become a real concern to pencil out.
I've been playing with using the CTEK as my primary controller -- I picked up a high wattage 12 volt power supply and am running it into the solar port. It gets warm to be sure - a few heat sinks may be needed. Boy, I tell you -- that CTEK is fast! I'm really wanting to see what it can do to lithium. Which I'm thinking about upgrading too...
Thats where I am at RN.
CTEK works great out of the factory and DIY if you have the wire switches set right for changed battree type (hint:RTFM)
I now need help backfitting the Victron shunt to the pre-2011 fusebox if you are into a Zoom or Facetime call...
Also using the Victron charger per others rave reiviews ...hopefully without keeling my bat-tree...i got that part down pat...
Nice tgng about the Precision battree is you can run that thing to just about nuthin' and still recover it with proper charger capability- or so the east coast victron rep claimed/...
strangely enuff the victron factory manual wire diagram was sumting wong no workee for me: but obviously user error...
Now been waiting on callbacks from victron marine techs in the busy season is not working here in socal...
Say, know any RV techs who know electrikal schtuff in teh baby airstreams?
