Matt Rogers
Hello everyone, I have been gone a long time, busy with work bla bla etc. and had to make a return to share an easy fix for a big problem a lot of us in the south have with the camp inn AC. So, like many others, my AC didn't run when it was hot out, or would run intermittently. Basically if it was hotter than 85 degrees, forget it.
The Crosley stock AC had a compressor failure and crapped out. No big deal, it's a basic 5000 btu window shaker. I used this blessing in disguise to research the hell outta AC units that fit the hole perfectly. Found it! Yes, it helps to keep the camper in the shade...but this AC is a trooper, not yet has it cycled off from an overheat. Camp inn is awesome though, they use Mortite type sealant that stays soft. So, taking the AC cover off takes about 5 minutes. The whole swap out took about 30 minutes. Also, now I have digital climate control, a remote, and an extra fan speed. it's a GE AEW05LQ. It was $140 from Sprawlmart, who is only place I could find it, hence the "W" in model number. They make the same one with different model number, but I could not find it anywhere for less than $200. I will keep everyone posted, but so far so good and we have had some hot weekends so far this year.
