Camper That Sat For 15 Years - What To Check?
KarenBee
We are going to be buying a 560 that has sat in a garage for 15 years unused. I asked the seller to get new tires and they got a new battery.
What about other things that should be attended to?
I want to keep this camper for a long long time and want to make sure it is good to go on the way home from our sellers place a few states away.
Thanks oh wise forum participants!
I would pay special attention to the water system. At a minimum, add some Clorox to both tanks and fill with fresh water, then drain, refill, and drain again. At the same time keep an eye to the plumbing under the left galley compartment and under the trailer to check for leaks.
The other thing I would be very careful of is the propane system. Check the date code on the tank to see if it needs to be pressure tested. Examine the hoses from the tank all the way back to the stove and heater (if installed); rubber hoses can deteriorate with time and ozone exposure.
The mattress could need attention, foam rubber doesn't last forever, it dries out and gets hard. It is possible that the addition of a topper could extend its life, though it may need replacement.
Finally, check the rubber gaskets around the doors, front windows, and hatch for hardening, shrinking, and cracks. Leaks are annoying.
Good luck and welcome to the group.
definitely agree with the battery, tires and wheel bearings comments.
Had not considered the water components, but now that it has, if you have a list of how the trailer is optioned out, if you can share that information, that will certainly help other forum members make better and more informed post in response to your question.
And congratulations on your soon-to-be new to you 560 !
Already went to the nest this spring. Buying used because we just couldn’t wait.
Congrats!
+100
on "the checkup for peace of mind".
Schedule an owners tour of your rig and be prepared to take copious mental notes- its a data dump of wisdom.
Insider tip: Read owners manual first...twice!
Or as I remind myself before asking Cary my enthusiastic noob questions:
"RTFM"
Btw: there's places here somewhere or the Official website to download the manual(s) in pdf...if ya dont have OE hard copy.
Pilgrimage to the Nest is a requirement to become officially Blessed as a CI Fanatic, so check that box.
Srsly-Its well worth the trip just to meet the fine folks at factory and see how quality they are made.
You will be amazed: its old school marine/aviation level craftsmanship and attention to detail
With that Midwest Maker tech coolness...
PS: Ask Cary about the hot tub option.
