jimtiffany
We're making final decisions for options on a 560 Ultra. The last thing we really can't decide is whether or not to get the furnace. We will be camping without electrical hookup occasionally, and we'll undoubtedly encounter cold weather from time-to-time. The choice is between the furnace or getting a 12 volt ceramic heater. We've talked to people who have each and they all like their choice.
It sounds like either one would be used only briefly to warm up the cabin. I'm wondering if a ceramic heater would be too significant a draw on the battery if we are out for several days. We will be getting a 100w solar panel, but I'm not sure if that will be enough to compensate for short-term use of a ceramic heater. Of course, the cost difference is a consideration, but we don't want to compromise ourselves in cold weather. Here's one example of the heater we'd be considering:
http://www.campingworld.com/shopping/item/12v-direct-hookup-ceramic-heater-fan/56984
This heater requires a direct connection (hard wired) to the battery. It produces 300w. Has anyone done a fixed installation like that? The models that plug into a DC outlet seem to be designed to be used in a car to defrost the windshield and pre-heat the interior with 235w or so max output.
http://www.my12voltstore.com/12_Volt_Heaters_s/76.htm
If you have a ceramic heater, what model? Where is the best place to position it? If you plug it in, do you need an extension for the cord to reach?
Jim & Ani
Jim & Ani
