Thanks!
You make some good points Steve, and the older I get, the more I understand the importance of good body mechanics. I am gradually having more aches and pains, and recovering from them slower than I remember before.
The straps I made will sit at the sides of the Dometic when it is stowed in the galley space, so the side table can still be stored on top as designed. If I remember correctly the PVC tubing I slipped into the webbing was about 1/2", so it just barely fits in on each side of the Dometic.
But the body mechanics issue was still there, so after reading your reply I decided to try turning my straps upside down so that they hang down, rather than up. That shortened them so that instead of laying across the top of the Dometic, they come up to just about the top edge of it, and also I noticed that the PVC handle portion can now be stowed in the grab indentations on the side so sliding the Dometic into the galley space can be done as easily as without them.
I did notice it was easier taking the unit down from the kitchen counter where I was working on it with the shortened straps. I'll give that a try for awhile, and if need be, I can still shorten them further and make new mounting screw holes in them with the soldering iron.
It's fun to compare not only ideas, but the reasoning behind them, and the constructive criticism here to make improvements we can all benefit from.
Thanks again Steve!
