Wendell Ann Hanks
What is the expected effectiveness in electric brakes for a 560?
Most important: What are the indicators of effective 560 trailer braking?
Our used 560's electric brakes (the magnet with shoe system)are not strong enough to hold the trailer in place from a minimal pull by our Tacoma v/6 truck. This is when the Prodigy controller's mechanical lever is moved fully to the left and the electrical setting is 13. A new magnet was installed prior and the system was then declared fully operational by an RV enter.The RV center technician also said level 13 volts was needed to get any appreciable braking response.
The Prodigy set-up instruction declares: First "lock the trailer's brakes" as a starting point for adjustment using level 6. This appears not to be the baseline for our trailer's 2,000 lb. rated braking system. There is virtually no braking at 6.
How much braking should be expected by the trailer's system? Is there a mechanical problem described here?
Thanks for any input.
Wendell
Wendell
