I concur with Alcat's and Randy's comments above, and perform both of their routines, most of the time. The only time I have the fridge plugged in, in the galley, is when it's 60F or below, and the trailer isn't parked or pulled in the sun, but when you still need refrigeration. The fridge comes on so infrequently, and the temp differential between the exhaust and the ambient temps effectively disperses the heat, even in the enclosed space. Under these circumstances I make sure there's nothing else in the galley and there's as much space for the air to move around as I can give it. No faults or excessive trapped heat yet.
