Members Map Pin Color Key
Jim Carter
Moderator
Staff member
Red = on the road (traveling)
Blue = 560 owner
Green = 550 owner
White = ordered
Brown = member of forum, but not a Camp Inn owner
Yellow = In Production
How does one go about adding your Pin to the members map? I bought Mewtons 560 #408 a few years back in Spokane Wa. We live just across the border from Washington in Dalton Gardens Idaho.
When you enter your home address and lat/long coordinates in your profile it should show on the map. If not, let me know and I'll try and help.
What color for 500?
Wonder why there is no color for Camp-Inn 500? Feeling left out. Didn't know about map when I first purchased my 2012 500 Special.
What color for 500?
Good question. You ARE a rare breed. Maybe Cary or Craig can come up with the appropriate hue for hyou.
OK, you're now represented on the Member Map. The key is adding your latitude and longitude to your info.
I’ve tried pasting several variations of this in home location:
45.xxxxxx, -122.xxxxxxx (x are digits I’ve replaced in this message for privacy reasons)
I’m getting this response:
Geocode was not successful for the following reason: REQUEST_DENIED
Am I pasting in the right place?
It worked. You appeared to have the correct format. Not sure why there was a problem. You may want to tweak the numbers a bit as I used the lat/long for 'Portland, OR'
Ah! That ‘splains it!
Apparently the lat/long boxes don’t show up in all browsers. Mostly I use Safari on an iPad; will check on some other devices.
Ken, can I get a 560 pin added to the Members Map? I think I've done everything correctly, except that I don't see a Lat/Lon box in my Personal Details section (I've checked both Chrome and Firefox browsers...nothing). I do have "Napa, CA" listed as my Home Location.
Done. Not sure why it's not showing up for you, but you're all set!
