Update: I put the vintage Griswold 202 (identical to the one pictured in the post above) through its paces.
It is slightly undersized, compared to the Camp-Inn OEM. But that is not the issue with trying to substitute it out, to get some vintage mojo into the galley: even with using a highly variable regulator off a spare tank, and a #72 LP orifice, and playing with the variable air intake at the orifice, I can't get it close to putting out a nice pinpoint blue flame at a low setting, like we are used to with the OEM. I can eliminate the yellow flame entirely, which means that it is combusting properly. But I can't get a better flame than the OEM.
This, however, isn't to say the Griswold is useless; it would be great for doing a pot of corn or other large batch outdoor canning, where copious heat output would trump flame control. I'm abandoning the idea of using it in the galley and putting that project (complete refurb and paint job) aside for now.
My experience with the Carolina Cooker (the casting was broken) ended with a full refund from the company. So I can't complain about that.
I will be using the CC burners and needle valve controls with the Camp-Inn OEM cast top:
You can see the CC burners are a tad smaller and a lighter casting than the CIs, and that the needle valve/orifice assembly can only be used on the CC burners, and not the CI burners. However, the needle valves do give more flame control than the CI 180 deg valves. And look marginally less utilitarian than the CI valve handles. Which, for me, was the whole point of getting the CC cooktop in the first place: to use the valve control parts.
The burners are interchangeable and use the same mounting holes. But I suspect that the CC burners put out slightly fewer BTUs. Which won't be a problem for me.
I will update again when I get the CI cooktop and the CC burners re-coated in a high-temp paint and back together again.
