Weak Gas Flow
gregangsten
Anyone have a problem with weak gas flow to the stove? Sometimes, I'll start the stove and can't get more than a tiny flame out of it. After a long enough time, it generally comes up and works normally. Plenty of gas in the tank and all fittings are tight as far as I can see. All I can think of to do is just replace that regulator and hope that does it.
Never mind...
I think I found the answer:
How do I reset the regulator on my gas grill?
Reset the regulator by turning off the burners on your gas grill. Turn off the propane tank and disconnect the hose from the tank. With your gas grill lid open, turn the burner knobs to high for about two minutes, and then turn them off again. Reconnect the hose to your propane tank and slowly turn on the gas.
I think the problem starts if you turn off the gas at the tank before you turn it off at the stove or furnace.
I just had this happen to me and your regulator reset procedure worked like a charm. Thank you so much for your post!
