GEN Y HITCH BALL MOUNT
If you want to get really serious about it, and its best to do this over time --- get a baseline when the car is new then do your analysis as necessary...
I have used them and they are fast, and give a great report. Taking the sample is SUPER easy and not at all messy, if you have a dipstick. Just run a plastic tube down and the pump siphons the fluid right from the case. Things like transfer cases and differentials are 'sealed' -- so you have to pull a fill plug to get to it...not terrible, but not as easy either.
I've seriously considered doing an ' Oil Analysis '.. I watch a lot of ' The Motor Oil Geeks ' Videos...;)
Based on my past experiences, along with my ' OCD ' topic research habits.. Every Vehicles Owners manual has some information regarding " Harsh Conditions-Severe Conditions / Heavy Use / Extreme - High Heat Climates " exceptions, to their regular/normal recommended Maintenance Schedules.
I decided to change the ' Oils & Fluids ' More Frequently, as recommended under the ' Subaru's 2023 Owner's Manual: ' Severe Driving Conditions', along with using a thicker Viscosity Motor Oil ( Changed @ 3,500 miles: 5w-30 or 5w-40 ) in Hot Weather Conditions.
EXAMPLE: 2023 SUBARU's OWNERS MANUAL: Page # 458
QUOTE: ".... HOWEVER, IN HOT WEATHER, OIL OF A HIGHER VISCOSITY IS REQUIRED
TO PROPERLY LUBRICATE THE ENGINE '.. :oops:
0W-8 Motor Oil: Too THIN to Trust? Let's Find Out! The Motor Oil Geek​
The Motor Oil Geek.
For the Record: I'm one of those guys that believes in " SLOWLY BREAKING IN AN ENGINE "... ;)
I was easy on the Speeds, No long Drives & I changed the " SYNTHETIC OIL & FILTER " at the first " 1,000 Miles ", then again @ every " 3 Months " ( Under 3,000 miles ), for the first " YEAR "...:cool:
SUBARU MAINTENANCE GUIDE
OIl & Filter Changes: 6 months or 6, 000 miles, whichever comes first.:rolleyes:
I now change the ' Oil & Filter ' every ' 3,500 Miles ' and use ' 5w-30 ' Synthetic Motor Oils, for everyday driving, based on my local Ambient Temperatures & Driving Conditions.
SUBARU's OWNERS MANUAL: Page #457
QUOTE: ' The engine oil and oil filter must be changed more frequently than listed in the maintenance schedule when driving on dusty roads, when short trips are frequently made, or when driving in extremely cold weather. '
They completely ignored / overlooked mentioning " EXTREME HEAT CONDITIONS ( Ambient Temperatures / TOWING ), which put additional stress on both the Engine & Transmission ( CVT ) Components.
I had to completely & thoroughly read the ' Subaru's Owners Manual ' to locate information.
Unfortunately, SUBARU USA was a bit deceptive by stipulating a set of recommendations in their Owner manual, and then another set of " CRITERIA " on different page/portion of their " OWNERS MANUAL ".... o_O
Just sharing additional info...;)
ENGINE LIFE EXPECTANCY CHART vs OIL TEMPERATURE
BASELINE- Approx Temps: 230 + / 250 + HOT
I will use the above info & average a baseline based on my " Personal Past Experiences - ( 30 + yrs ) TOWING ": Boat / U-Hail Type Trailers / & Teardrop Campers.
I'm also going to use some printed " DOCUMENTED DATA ", to use as a Guideline.
Just an ' FYI ".
Here's an interesting aftermarket product.
Subaru CVT Transmission Pan Billet Aluminum
I added a similar ' MAG-HYTEC Transmission Cooler Pan ' to my ' GMC TAHOE ".
I do Blackstone Lab samples on every other engine oil and each change of differential, and MT gear oils.
I am looking for making metal and/or oil breaking down in severe use.
I've not used Blackstone, I use JG -- but I think regardless you'll have insights.
I don't know about Subaru -- but sadly -- a Toyota (a major stakeholder in Subaru) are "sealing" their transmissions making it difficult for a professional home-owner to pull the samples. You need to get under the car and remove the inspection and fill cover instead of simply putting a tube down the dipstick. Not impossible but more of an hour job instead of 5 minutes. More of the s#!tification of cars today :(
Ford did the same to the SUVs claiming sealing the trans for "lifetime" - needs no service.
Why they got the nickname "Exploders" after awhile.
Interesting insights on ' MOTOR OIL VISCOSITY ', which applies toooo allllll Motor Vehicles....o_O
STOP Following OEM Oil Advice (GM Recall Proves Why)
The Motor Oil Geek
Posted 16 hours ago.
P.S.: ' I ' don't live in ' ALASKA '..Soooo, there is ' NO ' logical or rational reason for me to be using any ' OW ' Oils...:eek:
Just sharing additional information & issues with using ' Ultra Thin Viscosity Motor Oils ' in your Motor Vehicles....o_O
General Motors knew about V8 engine problems for years before giant recall, lawsuit claims
USA TODAY
Charles Singh , USA TODAY NETWORK
Sun, May 4, 2025 at 9:36 AM PDT
As of May 1, American automaker General Motors, which has a manufacturing plant in Tennessee, has recalled nearly 600,000 full-size SUVs and trucks (721,000 globally). This is the largest recall of 2025 in terms of affected vehicles. While mass recalls are big news, there's much more to this story than meets the eye.
The recall itself is cause for concern, but its timing has been even more troubling for some consumers who have long complained of engine issues, including a lawsuit filed months ago..................'
'................The lawsuit goes on to claim that vehicles equipped with the L87 V8 engine share a "common defect regarding the bearings in their engines which are prone to, and have experienced failure, resulting in breaching of the engine block by the connecting rod and/or engine seizure." ...'
Just sharing information.
The ' SUBARU ' has a known issue with ' EXCESSIVE CARBON VALVE FOULING ' due to its Direct Injection Fuel System.
I've been a ' Sea Foam ' fan for years.
However, I'll be using ' CHEVRON - TECHRON ' from now on.
I've also been using Chevron's Top Tier Fuel.
19X Difference In Deposits! [Engine Test Results]​
The Motor Oil Geek.
Can Premium Fuel REDUCE Engine WEAR?​
The Motor Oil Geek
Caution: near useless car geekery to follow,
Cuz I think there are a couple of odd ducks here like me who tow with VW gassers. Or lurking.
Same DI issue in the 1.8 and 2.0l EA888 tsi four bangers for VW Golf, Sportwagon/Alltrack, GTI, Tiguan, Atlas engines;
DI fouls valves slowly to where its worth addressing at anywhere between 75--150k, depending on who you talk with.
Its a $500-1200 job depending on how the shop does it.
I had mine done at 95k and it added maybe 5% more peppy by butt dyno, and supposedly less likely to fault the ECU into limp mode on heavy hot day towing. Which sux if you are in rush hour traffic on the Houston ring road in lane two avoiding the semis throwing sheds and other horrible Houston drivers in the merge.
First sign is rough idle on cold days, then slowly dropping MPG and maybe throwing an engine code I cant recall but is easily found with something like OBDeleven phone app and OBD plug-in BT device.
VW issued a TSB to add a can of their special stuff every other tank if unable to get Tier One gas, per owners manual.
Basically its the same "Techron, Synchron, etc solvent in the Tier One gas, I have a box ready for trips- Liquimoly sells a cheaper version of same stuff as VW.
I'll put a can in on a long trip if the only gas is at Love's for example, or a rural station with only 88.
Costco is Tier One btw.
GM 6.2 L87 Recall Update With Lake Speed Jr.
Posted 11 days ago.
Bearded Ford Tech
QUOTES:
" ' I ' don't live in ' ALASKA '..Soooo, there is ' NO ' logical or rational reason for me to be using any ' OW ' Oils...:eek:
I will be using a " Higher Viscosity SYNTHETIC Motor Oil ", to meet the " ** REQUIRED ** ( SUBARU's OWNERS MANUAL ) HIGH AMBIENT HEAT CONDITIONS " ( SUMMER ) and while TOWING. E.G.: 5W-40 SYNTHETIC Motor Oil. "
