Ill try the peroxide. The bottle of RV enzyme doesnt help with the smell.
I think the reason for that is soapy water. Black water is raw sewage, and actually decomposes if left long enough, think septic tank. Whereas Grey water is soapy water, food particles and cooking oils. That's why I use small bins to wash and first rinse, and dont pour down the drain, you can dig a small hole or pour around a tree to get rid of it, in nature it breaks down quickly and the food particles are beneficial. I use a bio degradable soap that breaks down the oils as well. The only thing I pour down the drain is the second rinse water, or plain water, so not much soap. I was also told to keep the tanks full when storing to minimize oxygen in the tanks. So far so goodfollowing this -- my grey tank is a little funky too. In fact my 'goal' today was to pull the camper out and just rinse the daylights out of it with warm water. Try to liquify some of the oils, which is probably the biggest source of odor.
A good friend of mine does tank flushes on large rigs, and he's said it a couple of times. He'd rather flush black tanks than grey -- the funk that is in the grey smells 10 times worse than the "effluent" in the dirtiest of black tanks.
Thanks, ordered and giving it a try.Just a quick update on this! As some of you know, my wife runs an animal rescue. The downside of this is that often we have far more critters in the house than we should, and this often results in far more....what can I say, its adds a je ne sais quoi to my home? Yah, lets go with that.
She uses this stuff in her rescue, and it does an amazing job controlling that certain somethingI added it to my grey tank before I took my last trip, filling the tank with water and just letting it sit for a few hours. The difference was night and day! I just went back from a 4-day excursion to northern Michigan (45 at night, 70's during the day --- amazing blue skies!) and found the odors were still slighty present, but were knocked down by 90% -- I'll be adding a few more pumps and refilling the tank, allowing the enzymes to work for a few days. We'll see how it works at CICO, which is our next planned trip.
I like your idea. The simpler the better.All this talk about the putrid smell coming from the tanks and the difficulty getting rid of it makes me wonder if it's worth it to even have the sink. I choose not to with my build and don't regret it. Instead I use a very low tech solution for my water needs. This to store the water: https://www.walmart.com/ip/Reliance...6?classType=VARIANT&athbdg=L1102&from=/search And this to collect my gray water: https://www.lowes.com/pd/United-Solutions-5-Gallon-General-Bucket/1000462835
I empty both at the end of each trip - often in the fire pit if we've had a big fire going. The water jug will also accommodate a portable shower: https://www.amazon.com/dp/B07WGMDBDF?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_2&th=1 It requires heating up a pot of water to pour in if the weather is a little cold. But this method has served me well.
Thanks David!Like others on the thread, I just drain mine wherever. I usually just unscrew the plastic ball valve and let er rip. My gray tank only has
Mildy soapy water and no food particles. I wipe my dirty dishes with a paper towel before washing. At home I drain in the driveway. I’ll admit I am a criminal in that occasionally drain right at my campsite. For the record, I usually boondock or camp at BLM or Forest Service Campsites out in the middle of nowhere. It’s only 8 gallons of soapy water. No different than washing dishes in a tub and dumping the water. I do camp in bear country often and I am mindful of keeping a very clean campsite. I’ve thought about whether the dirty water might attract a bear. But I think it’s unlikely. Never happened yet. As I said, it’s 8 gallons or less of water. It soaks into the ground and in a couple hours the ground is usually dry. When I first got my trailer (2011) I had a hose to drain it. Never used it. I’ve camped pretty much all over the Western US, the eastern US. Even went up to the Arctic Ocean. Camped in BC, Yukon, etc.
