Steve and Karen
My two cents on the Backroads... with pictures:
I waited for frozen ground so I wouldn't make a mess of things. I was able to put it up myself NP in windless conditions. Any sort of breeze and I would definitely want some help.
There's lots of head room. I'm 6'4" and wasn't confined to a small area. The footprint is 6' wide at the trailer, 7 1/2' at the back and about 7' deep. So... plenty for two to make a meal, with a heater going, and places to sit, with maybe a folding table or the CI rear table set up. I didn't try it but the table extension would likely still work.
It staked out well and was fairly intuitive to set up. Once installed, it seemed like it was designed for the CI.
There were some gaps in the side that needed closing up to make it truly weather-proof and retain as much of the heat as possible:
I was able to accomplish this, drawing the two pole ends together with some of the copious amounts of webbing that came with it:
These are the short sections of webbing at the pole ends. Because of the way they are stitched, if you use these short ones for holding down the corner to the fender (rather than across the hatch hinge), it will likely rip out over time. I hope this demonstrates what I'm cautioning against:
The pole ends can be secured to the far side of the fenders, much the same way the CI vestibule is secured:
There's a ton of extra webbing that I eventually will be dispensing with in favour of a simpler, quicker and less messy set-up.
The only thing that screams "not made specifically for the CI" is where the canopy contacts the corners of the hatch. These require some protection lest you wear a hole in the nylon:
I am looking for a "sand mat" or something that can fold up and be held vertical at the bumper. This will hopefully minimize drafts from entering the area from beneath the trailer and make it truly a warm, weatherproof cocoon.
This will also make a great shower/change room, since most of those tents are pretty small to begin with.
I didn't attempt any configuration using collapsible poles at either the front or the back to create a traditional sun/rain shade/shelter, or tried to attach it to the side door, since I was most concerned about being able to work out the bugs for a tight, cold-weather shelter. Those other configurations should also be fairly simple to figure out in time. Using poles at the front would likely also eliminate the problematic contact points at the corners of the hatch.
Now that I'm thinking of it... I didn't test the structure's stability with the hatch down. Maybe someone who has done it can comment on that, and if there are any modifications or precautions that need to be taken. I do know that with the hatch up and secured the way I had it, it isn't going anywhere.
