Les Izmore
We had occasion to use our camper's spare tire yesterday, just short of our camper's five year anniversary and after many miles on the road. We had just crossed into North Dakota, where I was waiting for Alea to finish up our cycling for the day. We loaded her up and went on our way, having accelerated to about 30 mph when we noticed an odd sound behind us. Alea quickly pointed out that the curbside tire was flat. I immediately pulled over and slowed down. At that point there was no shoulder on the road, and about an eighth of a mile ahead was a driveway apron that would allow us a place to jack the trailer up and substitute the spare tire. In that short distance and after crawling along at a pace of 5 mph, the trailer tire was shredded - something that has never happened in my prior driving experience.
Why this tire shredded I can only speculate. I suspect the main reason may be that trailer tires are not designed to hold up when they go flat in the same way that most passenger tires do. I would further speculate that makes them a lot less expensive to produce, and ours were significantly less expensive than our passenger tires. But having traveled in some fairly remote areas, I would like to know for sure. So if anyone can help in this regard, we would be very grateful.
I suspect this may be why some owners have opted to put passenger tires on their campers. And if that is the means of avoiding a repeat of yesterday's brief drama, we would certainly plan on doing the same when it is time to replace the current tires. We would much prefer having a tire that was repairable vs trying to approximate a reasonable match to our surviving tire...
I will also note that I had failed to heed the advice of the Owner's Manual to periodically check the pressure of the spare tire, which should be inflated to 65-85 psi. Ours had 40 psi when we put it on, but since we travel with a bicycle floor pump, it was easy enough to get them up to spec (which is why we hadn't been too concerned about the condition of the spare). Though with it being 97 degrees out at the time, I did wish that I hadn't let it go quite so long...
Those of you traveling without a bicycle floor pump or electric compressor might want to check the pressure on your spare tire the next time you pull the mattress out of the cabin for other routine maintenance.
