I started to winterize my trailer today and as I was emptying the fresh water tank I noticed a slight smell.
The trailer unfortunately did not get used much this summer, but I always topped off the tank after each trip. BTW - I only use the tank water for washing pots/pans.
I was starting the winterizing process, opening the drain valve I noticed a smell and some black slime inside the tank near the removed the cap.
Should I address this issue now before I add the antifreeze or address the issue in the spring while preparing the trailer for the summer season?
I remember reading something about adding some bleach to the tank with water then driving around with the trailer to get the bleach mixture slashing around inside the tank. Is this the correct way to address this issue? If so, what ratio of bleach to water or are there better solutions?
Thanks.
Bruce
Thanks.
Bruce
